Dakota front end swap
What year Dakota parts do I need for the swap thanks for yalls help
- PFM-64f100
Re: Dakota front end swap
88 to 93 ish I do think. For sure a 90's will work. Watch the springs there are two different ones (4 banger and 6 banger). If you have a big eninge (429/460) you will want the bigger springs. Also note if you want 5x5.5 rotors (other wise it is 5x4.5) you will need to use the ram brakes setup, it will bolt to the dak spindles. There is a post somewhere here that outlines that.
64 F100 short bed-style side-460-c6-with side toolbox and Dakota Front Suspension
And a 65 CrewCab
Chris W.
The pickups
65 Crew Cab
http://www.purpleflyingmonkey.com/CrewCab/index.html
64 F100
http://www.purpleflyingmonkey.com/1964- ... index.html
The Torino project http://www.purpleflyingmonkey.com/1971- ... eFile.html
And a 65 CrewCab
Chris W.
The pickups
65 Crew Cab
64 F100
See second link below for Install Instructions, which include model year range, and big bolt circle brake source info, etc.......
http://www.industrialchassisinc.com/?cat=5
1961-1964 Ford F100 Dodge Dakota Installation Kit
https://docs.google.com/document/d/1td7 ... edit?pli=1
Thanks guys I met a guy yesterday that has a 58 ford and he used the whole frame from the dakota
