Rods 63 UNI long bed ProStreet
kstones63
Re: Rods 63 UNI long bed ProStreet
Post by kstones63 »
That sure beats the heck out of laying on your back doing that. That body looks to be in geat shape.
Kevin
kstones63
_______________________________________
63 F100
29 Ford Sedan Delivery
99 F250 PSD, 4x4, CC
95 F350 Flatbed Dually Diesel
slickmainer
Post by slickmainer »
when you gonna sell that uni pig spinner? That would make things way easier :mrgreen:
--Gregg--
you can't get there from here
oldtrucks
Post by oldtrucks »
Got a lot done today pretty much got the bottom cleaned. The torque box is near perfect and the step wells appear to be made of galvanized metal. Other than the floor pans the truck is really nice. While Rod was cleaning the bottom I started welding in the floor pans and fitting the transmission cover.
Image Image Image Image
Mike Kincheloe
Mikes Old Trucks
I restore old trucks and cars
1962 UNI Short Box, Stock Y block, 4 speed Image
1972 F 250 4X4 429 4 speed Dana 70 rear
1977 F 350 Camper Special, Ranger, Super Cab
1950 F7 Cab and Chassis
1976 F150 4 Speed 4 X 4
1996 Taurus
dragginwagon
Post by dragginwagon »
i wonder if the 63's had some kind of galvanized metal for the steps? i parted out and scrapped a 63 uni that appeared to have galv steps.... they were some of the best parts on the truck and about the only thing not rusted through. truck came from new york so you can imagine the rust issues.
62bigwindow
Post by 62bigwindow »
I bought a set of NOS steps and rockers for my uni and both pieces were galvanized.I am not real sure but I think Ford did this quite often.I can remember some of the past trucks I have owned and or seen that were this way.
Every day above ground is a good one
Robert
Post by Robert »
any thing new on this unibody
EZBNGRN
Post by EZBNGRN »
:D :D :D found the march pulley kit on ebay got it all including power steering pump and new 130 amp alt for 350.00 all new..i dont really like the alt up high like that but after installed doesnt look to bad i can live with it..plus new ceramic shorty headers Image
oldtrucks
Post by oldtrucks »
Got a bit more done to the floorboards. Started making patterns for the cab supports. I'm using a members diamentions and finding that I need to make a few adjustments for this application. None the less they are going to work out really good.
drivers side cab support pattern. I'm using poster board to check fit the support before I cut them out of 14 guage metal and weld them together and tack them in. Next we will bring the frame to the shop and set the body down on it to make sure every thing fits like it should and locate the holes in the support assembly.
We will locate the engine and transmission and fab the mounts while the frame is here.
Mike Kincheloe
Mikes Old Trucks
1996 Taurus
oldtrucks
Post by oldtrucks »
Got the passenger side cab mount fabricated and temporarly installed. here are some more pictures. Used the Plasma cutter to cut out the pieces. It is made of 14 gauge so without a brake I had to cut reliefs along the bend lines to be able to make good bends. I'll turn the truck over tomorrow and begin the same process on the drivers side. Won't be long now and we can bring the frame to the shop and begin the fit up and engine and transmission install.
Image Image
Mike Kincheloe
Mikes Old Trucks
1996 Taurus
oldtrucks
Post by oldtrucks »
Made a little more progress today. Got the final pattern made for the drivers side cab support and the pieces cut out, de-burred and bend lines slotted. I'll bend them and tack everything together tomorrow. As soon as Rob gets in off of this run we will bring the frame up and begin fitting it all together.
The link to the photobucket album
http://s214.photobucket.com/albums/cc19 ... I%20Build/
Mike Kincheloe
Mikes Old Trucks
1996 Taurus
HiBoy63
Ireland
Post by HiBoy63 »
Looking good Mike.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
2001 Sport Track 4x4x4.0
In case you are wondering thats Ireland......Freedom is not Free!!!!!!!!
Heritage country Flag
noley99
Post by noley99 »
Very nice work. :thumright: Wish I had the tools and shop to build my own stuff.
Family First!
oldtrucks
Post by oldtrucks »
Ok I got the passenger side tacked up and tacked in place. Need to do a couple of minor things and then we can bring the frame up and put them together and see what happens.
Image Image Image
Mike Kincheloe
Mikes Old Trucks
1996 Taurus
oldtrucks
Post by oldtrucks »
We're ready to bring the frame in but it is about 15 miles away at Rob's house and it is raining so I don't want to get it wet with wet road crud that makes a mess to clean up. So sometime in the next day or 2 we'll get it here and the body on it.
Album link: http://s214.photobucket.com/albums/cc19 ... I%20Build/
Mike Kincheloe
Mikes Old Trucks
1996 Taurus
oldtrucks
Post by oldtrucks »
Ok got some more done today. The frame and body are joined for now. Looks like its all going to fit like its supposed to. The new cab supports fit good so all is good. We are going to hang the core support and fenders so I can check the inner fenders and do the cutouts for the upper control arms.
Image ImageImage
Album link
Mike Kincheloe
Mikes Old Trucks
1996 Taurus
MadMaxetc
Post by MadMaxetc »
Looking good! You are doing a killer job so far.
I hope my Mounts fit up. :|
My Build Thread
oldtrucks
Post by oldtrucks »
Well it's been a while but we got some more done to the truck. Inner fenders trimmed and cab supports drilled. Every thing is lining up real good. Painted the transmission so we can marry it up to the engine and begin setting that up. Probably start that tomorrow. After that its time to mock up the steering colum and brake pedal assembly.
Here's a couple of pictures.
Mike Kincheloe
Mikes Old Trucks
1996 Taurus
SixtySix Ford
Post by SixtySix Ford »
love your project! But whats up with this pic? :oops:
"Nitrous is like hot girl with STD's. You know you wanna hit it, but your afraid of the consequences."
66 Ford F-100 - Project SickUp
EZBNGRN
Post by EZBNGRN »
that was from putting a high volume oil pump in a stock pan and a so called mechanic with 35+ yrs experience :cussing: :?: didnt catch..should have seen a leak on the dyno,small but noticable,and no QC at all.but one phone call and they made it right..gave me a chance to open the motor up and check things out.makes you wonder sometimes more quantity then quality.next build will tackle motor myself
SixtySix Ford
Kinda figured as much...lol what all do you got done to the 302 besides heads? Just wondering the need for a high volume pump..... :?:
