azratrods '64
azratrod
brake line / fuel line / wire clips
Post by azratrod »
so i couldnt find repop fuel line clips, brake line clips, or wiring clips. so i bought clips from totally stainless. i got double clips to run the brake lines and fuel lines together along the frame. i also got some singles for the wiring. i know they are a little fancy. but they will look great against the gloss black on the frame and there safer then old rusty original clips. sometimes you have to make a few exceptions when it comes to safety.
'64 ford bbw custom cab short styleside bed
'32 ford 5 window body
'28 ford roadster pickup
'04 ford f150 crew cab short bed
azratrod
clutch linkage with heim joints
Post by azratrod »
so we need to modify the clutch linkage a little. actually shorten it and add heim joints. i blasted the rod and now we are going to shorten the rod and then put a couple nice threads on each end. one end will get just a standard 3/8" heim. this is the end that goes up to the clutch pedal and attaches to it. the other end of the rod will also get a 3/8" heim but it will have a bolt through it. this bolt will attach to the clutch.
standard 3/8" heim
the rod with the heim. the 2 bent ends on the rod will be cut off. then the rod will be shortened and threaded.
MadMaxetc
Post by MadMaxetc »
Thats what I did to my linkage on my 67. MUTCH BETTER.
I also did the Pettle Bearing upgrade.
http://s63.photobucket.com/albums/h142/ ... 20Upgrade/
My Build Thread
TheOPWK
Re: how the truck sits as of 5.1.2011
Post by TheOPWK »
azratrod wrote: im not going to run the original inner fenders. Image
since you arent going to run them. . . . I know a guy who needs a passenger side one. 8)
Scott R.
azratrod
clutch linkage bearing idea
Post by azratrod »
madmax: geeze! thanks alot. now i HAVE to do that too. it looks great and if it helps the truck function better then im all for it. its the little things that count.
OPWK: come and get em. there at garbzs house. actually come get them when you come over to help scuff, sand, and paint (hint)
Max
Post by Max »
Coming along nicely! Good group of fellas over there in the AZ.
"If you don't want to stand behind our Troops, feel free to stand in front of them."
1964 Ford F100
1967 US Army M416
TheOPWK
Post by TheOPWK »
Deal. You just le tme know when.
Scott R.
MadMaxetc
Post by MadMaxetc »
Glad I could help. :twisted:
My Build Thread
azratrod
just call
Post by azratrod »
opwk: just give me a call when ever. ill be there all this weekend and next
azratrod
steering box mounted
Post by azratrod »
got the 66 steering box cleaned, painted, and mounted. here a couple pictures.
had to go to a wrecking yard to find the 3 bolts for the steering box. they were still being cleaned when i took these pictures.
the other hardware will all be either grade 8 or stainless
the mounting plate was bill w.'s who lent it to us so we could have steve at industrial chassis make us one. he actually made a few so they could be sold if anyone is interested in running this type of steering set-up.
azratrod
3 duece offenhauser intake for the y block
Post by azratrod »
i just got this 3 duece offenhauser intake for my y block today in trade. the carbs will need serious rebuilding or new ones bought. ill worry about that later. i feel like a fat kid in a candy store!
Greg D
Post by Greg D »
Yea those carbs have "issues" - intake looks real nice though!
azratrod
offy intake mocked up
Post by azratrod »
here she is just mocked up on the y block
drivers side
passeger side
from the front
azjake
Post by azjake »
Lookin' Good!!!
Jake
I think I'll go to the "Spousal Avoidance Center" (workshop) for a while...
azratrod
as of 5.14.2011
Post by azratrod »
here are some pictures of the work that garbz and i got done today. enjoy!
pitman arm with heim joints mocked up
fuel pump and cannister painted, mounted, and stainless bolts installed
new oil filter
master reinstalled. this time with the newly painted plate and stainless hardware. fuel lines coming tomorrow
steering column mocked up. notice where it exits at?
inside view of the steering column
from the right side. remember... this is a '64 truck with a lower dash section from a '65-'66 truck. the column is from a '65-'66 also
clutch linkages new heim joint. mocked it up today. still waiting on the other ends heim joint
brake lines beginning to take shape
left rear
down the frame rail toward the proportional valve. fuel lines to come tomorrow
using some pipe to mock up the double d shaft
cant get much straighter and level then that!
mocking up the u joints. used garbzs u joints from his unibody
azratrod
hood finished been punched and back home
Post by azratrod »
so i picked up the hood today. it look awsome! 84 louvers on each side. thats a total of 168. here are a few pictures of the hood as it sits today. it needs a little hammer and dolly work. then back to the blaster for a lite touch up.
if you look just right you can see how the louvers are angled just slightly to run with the angle of the hood peak. its hard to tell with the swirls that the sander made in the primer
Greg D
Post by Greg D »
Outstanding!
Exactly how I was going to have the Uni's hood done.
Hookedtrout
Post by Hookedtrout »
That is awesome, looks like that's how they should have come from the factory.
Cory
1962 F100 SWB Unibody, 223
1931 Ford 5 window coupe
1968 GT/California Special Mustang, 289
Complete 61 LWB Unibody parts truck with 292 Y Block
azratrod
a sneak peak of the tri power
Post by azratrod »
this isnt my tri power intake. but its exactly what i have and how its going to look when im done. im going to be sending my whole set up to a guy named dick at dicks hot rod carbs. his site is: dickshotrodcarbs.com this is a set up he did awhile back and exactly what im looking for
Bill W
Post by Bill W »
So... your not using the COOL air cleaner you bought?
i think it would look nice on top of 3 carbs!
