I (Like everyone else on the planet) would like more miles out of my outrageously priced gasoline.
Truck is a 66 Ford f-250 with 4.10 gears, 4-speed and stock 300 6 cyl.
Mileage is 13 mpg.
Carburator is Carter YF.
Truck is heavy.
RPM's at 65 are 2800-2900.
Would a overdrive transmission help?
4-barrel intake?
EFI exhaust manifolds?
Thank You!
Better Mileage
- Blackwaterforge
Better Mileage
If it cain't be fixed with a sledge hammer it must be an electrical problem!
Motocentro
OD trans would definitely help (would reduce RPM's at highway speeds) but you have to weigh the cost of the sway v.s the savings
Don't get a bigger carb or intake, but EFI does help - again, weigh the prices.
Shorter rear gears would certainly help.
Replacing the head with a 240 head will raise compression which will help to a degree as it will increase power production at all RPM's.
You should check these guys out - IIRC there's a whole section dedicated to this:
http://www.fordsix.com/
My new signature.
- Blackwaterforge
the t5 might be a bit weak for that
but the ZF or NV will handle that
http://www.high-impact.net/transmission ... 5&6spd.htm
http://www.high-impact.net/transmission ... 20Packages
Motocentro
- Blackwaterforge
similar to the clark 251V and VOBlackwaterforge wrote:Thanks Guys!
What about a Clark 280VO?
Are parts available?
Is it a direct bolt in?
they use the early fat input shaft spline and bolt pattern and are mounted with the ears of the bell housing. used on the medium duty trucks, they are also a heavy weight, 186 lbs.
would bolt up to a 240/300 6 with the eared bell and correct pilot bushing but there is no way to mount it to your truck without also using the crosmember for the bell.
only an issue on the twin i beam trucks, the rest 61-64 and 4x4 (except 66 f100 4x4)not a problem.
- robert porterfield
