Horn repair
NY, NJ, PA, DE, DC, MD
Marty in PA
Horn repair
Post by Marty in PA »
Have to perform surgery on the horns. Any idea how to remove the horn button in the center of the steering wheel on a '65 F100?
Thanks,
Marty
Keep warm!
Marty
1965 F100 Short Bed w/390 and 4 on the floor.
When half of the people get the idea that they do not have to work because the other half is going to take care of them, and when the other half gets the idea that it does no good to work because somebody else is going to get what they work for, that is the beginning of the end of any nation.
Fanatic
Post by Fanatic »
Push down and turn counter-clockwise !
Marty in PA
That worked but it looks some internal patrs are missing ie the contact brush. Any idea where to find a diagram? I would like to what supposed to be there before looking for parts..
Marty
Jonas
Post by Jonas »
Marty I am trying to to do same thing. I would like to see a diagram of what should be there. I have the center piece and a large spring. I think I am missing the small sping conducter.(can be bought for less then 10 bucks from DC. I think there might be a rubber piece needed too.
1966 F100 SWB 390/Toploader/Ford traction Loc
1997 F250HD 460 4X4
2004 RoadKing
1984 FLHS
1978FXE
Marty in PA
It is obvious someone before me removed the steering wheel (or tried). I'm kinda thinking some other parts might me missing once I get the steering wheel off take a look around.
Yeah I have seen the catalogs like Carpenter, MAC etc parts aren't expensive. If it needs other parts though I would like to begin by knowing what supposed to be there.
If I find an exploded view I'll let you know.
Marty
Marty
DV65CustomCab
Post by DV65CustomCab »
Is there one in the LMC catalog? It may be accessible online. From memory (and I've had mine off a few times) it's the chrome buttone, the 3 prong plastic retainer, the big spring over the nut. There's the small spring/brush thingy that goes in the little hole towards the bottom. To go further I think you have to remove the big nut and pull the wheel or at least the metal plate (?) and there is a second spring/brush down there somewhere.
As always, you're welcome to stop by my freezing cold garage and I can twist the knob off for you. :)
Stop The Longbed Hate! :)
'65 F100 Custom Cab bought 2002/Sold 2014
Now: '93 F150 Lightning
Marty in PA
Thanks. I have been wanting to cross the river and visit you just haven't gotten there yet.
Marty
Marty
slickmainer
Post by slickmainer »
im not at my desk to look at the real books, but here is a pic i have had. it might help?
--Gregg--
you can't get there from here
Marty in PA
Thanks!
Great Stuff.
Marty
Marty
Fanatic
Post by Fanatic »
Man there's ALOT of parts in a column...............note to self........DO NOT take column apart !
Marty in PA
good advice. I'll stick to te horn.
Marty
DV65CustomCab
I'd like to get a 'spare' column to take apart before I'd ever attack mine. Either that, or it gets shipped to Flashback Tom for a rebuild.
65 66 Ford
Post by 65 66 Ford »
The hardest part of rebuilding the steering column is removing the wiring pins for the turn signal switch and horn from the two plastic connectors. Just make sure that you mark the location of the wire pins.
Fran
65 Ford F100 CC style side looooongbedddddd
Be American buy American
DV65CustomCab
65 66 Ford wrote:The hardest part of rebuilding the steering column is removing the wiring pins for the turn signal switch and horn from the two plastic connectors.
The hardest one is the first pin. After I figured it out the rest were done in minutes, but they are fussy little things.
66fordtrucknut
Post by 66fordtrucknut »
Fanatic wrote:Man there's ALOT of parts in a column...............note to self........DO NOT take column apart !
I'm trying to never take anything apart again.
Charlie
62' SWB uni 223
66' F-100 Short/wide 352
78' F-350 dually dumpbed 400
12' F-150 5.0 3:73 LS
DV65CustomCab
Charlie
But you've got excellent experience at it. :rotflmao:
66fordtrucknut
Wish I had the experience of putting them back together. I'm still trying to get Subaru back together. What a PIA went from a cv replacement to ball joints now wheel bearings, had to take the whole lower control arm/hub off to cut the balljoint in half with a grinder to get it apart and the pinch bolt was rounded off by a po, thats how my weekend went last weekend, oh plus snapping off 2 breaker bars getting off the axle nut.
Charlie
62' SWB uni 223
