Lower by leaf removal, which ones?
- Southern64
I am sure this has been discussed on here but I could not find in a search. Since I put the new shocks on the front of my truck it is bulldoggin bad. Which leafs can I remove to take her down a few inches without causing too much trouble?
- Southern64
- jkimbrel65
I removed every other after the first main 2 so far no problem with bump steer, or soft ride. . Looks real good and has not bottomed out yet. I did the flip, and when I put everythiung back the drag link was resting on the oil pan...not good.. So i went back to the original way and did the remove a leaf method.. I still have to do the rear....I will try to post pics.. Ryan
- Southern64
The suspension is pretty soft this way - you won't be hauling anything. I removed every other leaf starting just below the main. DO NOT take out the the little S shaped leaf - this one keeps your spring from getting stuck in a dearch and softens a bottom out.
Over all it didn't drive bad like this - I now have monos on the front and they are better and worth the $ IMHO.
Stock height;
[albumimg]2260[/albumimg]
With 3 leaves removed;
[albumimg]2815[/albumimg]
[albumimg]2814[/albumimg]
It was quite abit higher even though it doesn't look lowered much with those tires.
[albumimg]2374[/albumimg]
[albumimg]2375[/albumimg]
This is before the monos;
225x60x15s on 15x7" front
275x60x15s on 15x8" rear
Stock height;
One other note;
I would not use this for a permanent solution to lowering a truck.
- Southern64
You have to of course drop the axle off the spring. The bottom of the "bolt" is simply a rounded head - nut on the top. Grab it with a pair of vise grips and take off the nut.
After you remove some leafs the "bolt" will be too long. My solution to this was to go to the hardware store and get a stainless alan-head bolt & nut to replace it of the new correct length. Think it was a 5/16s or 3/8s. I used a drift in the hole and a C clamp to hold the pack together to install the new alignment pin (bolt). Take your time and be careful - there is alot of pressure on these as you are clamping them back together.
I'm just thinking out loud here, and someone chime in & tell me I'm an idiot if you know better.
Is it possible to invert a spring pack?
Take the whole pack apart, turn all the leaves upside down, then restack them in the same order - so the smallest spring would still be against the axle.
In my twisted little mind, it seems like that would get you a good drop without loosing the benefit of the load carrying capacity of any of the leaves...
The center of the spring would likely hit the bump stop before you got all the shackle bolts back in. If you take a spring and have the eyes reversed they basically just rearch your spring in the opposite direction.
I left the bumpstop in place with my monos.
I have the reverse eye monos too, F 250 shackles (they are thicker), all new bushings - I am 1.5" off the bumpstops with a 5.0 & T-5 under the hood. It may settle to 1 1/4" after everything is back together.
I got mine used but near new from another member who thought them too low. Tom @ Flashbacks is about the best place to get them;
http://flashbackf100s.com/
